AC Delete Pully
Old Jan 24, 2006 | 01:19 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
AC Delete Pully
I have a 92 Camaro RS 3.1 V6, what I want to know is if the pully listed on GMPartsDirect.com (#10055890) will fit my engine or if it is only designed for the V8's. I know this has been beat to death, so I searched and found the article, but it say's, "This pulley is originally for 88-92 f-bodies and caprices that did not come with a/c that were equipped with an L98 engine".
Ok, going in a clockwise motion starting at the throttle body, my accesories go AC, power steering, Crank pully(with water pump right above it), smog pump, altenator, tensioner.
Any help or suggestion is much appreciated,
Max
Old Jan 24, 2006 | 01:26 PM
wizman073's Avatar
Car: 1987 Firebird
Engine: LB8, 2.8L V6
Transmission: t-5
If you get rid of the A/C you can just go out and buy a serpentine belt that will fit w/o the A/C pump on the car. Thats what I did after removing my AIR pump.
Old Jan 24, 2006 | 03:23 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
yeah, my 89 service manual showed a non-ac belt routing, it didnt have any idler pulley where the AC was.
Old Jan 25, 2006 | 09:04 AM
myvmax1's Avatar
Car: 91RS, 91RS
I tried just getting a belt go accros the gap, but I couldent get one small enough make it from the powersteering to the altenator without the belt rubbing the top of the waterpump pully. Might have just need to go alittle shorter.
Also, when getting rid of the air pump, will that long section of unsupported belt cause any flapping, other complications at high RPM?
Thanks,
Max
Old Jan 25, 2006 | 09:41 AM
wizman073's Avatar
Car: 1987 Firebird
Transmission: t-5
No, the belt will not flap, provided you get the right one. Some 87 ons came from the factory without the AIR pump because they burned clean enough. I have no A/C or AIR and my belt fits great.
Old Jan 26, 2006 | 09:11 AM
myvmax1's Avatar
Car: 91RS, 91RS
One last detail, All I've ever used is off the shelf belts from autozone. I've seen some belts on here that looked thicker and more durable, better quality, less likely to stretch. Anyway, do i need one of these belts, and if so, what is the brand name? And does anybody have the belt size I will need, if not I'm just gonna try them out in the part store parking lot.
Thanks,
max
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
