spark plugs taking a gas bath
Old Jan 31, 2006 | 07:16 PM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
Well it's been awhile since I was here,its good to be back!!!It's winter time where I live and my gremlins are back and in full force.It can get pretty cold here and a batteries life can be short.The problem is that my 2.8l mpfi Firebird('87),has what appears to be a flooding problem.
Here is a typical day,walk out to car,get in, put key in ignition switch,turn to run,hear fuel pump energize, wait till it stops,turn key to start,engine cranks.......and cranks.........and cranks........are you getting the picture yet?Turn key off ,engine still cranking.....yupp.......key in the off position but engine continues cranking.Once engine stops,get out, lift hood, pull spark plugs and they look like they've been taking a bath in gas!
The starter is new,and the cranking time is about 5-7 seconds; battery was fully charged over night,this problem is such that when or I should IF the car starts,when the day is done,I remove the battery and bring it in the house and put it on the charger to keep it ready for the next day!
Summertime the problem isn't as bad although it can be b***ch,to start at times.Sometimes it cranks over great,sometimes it struggles to the point where i begin to cry for it.
Any ideas
Old Feb 1, 2006 | 09:24 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
87 = MAF
MAF = cold start injector
Check the CSI
As for the cranking, your ignition switch (the electrical side) is probably broken
Old Feb 1, 2006 | 11:06 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
also clear flood mode is activated by pressing the gas all the way down when you crank. and try just starting it up right away without waiting for the fuel pump to do its thing. the CSI is probably just spewing fuel that whole time.
Old Feb 1, 2006 | 11:33 AM
87pontiac's Avatar
Car: 87 Firebird
reply.....
Thanks alot guys at least now I have Isome direction.Fresh plugs,wires,cap and rotor........once I get another MAF sensor I'll give a try............as for the starter problem that will be dealt with.
Thanks Alot!!!!!!
PS - All other input is still greatly appreciated!!!!!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
