AC delete...anyone ever get right belt?
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
After taking off my smog pump off my 3.1, I am looking to take the AC system completely off. Has anyone ever figured out what size serpentine belt is needed to run without the smog pump or AC on a 3.1 V6?
Ken
Ken
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you would have to have an ac delete pulley to run a combo like that. you can't "string" the belt from the alt/tensioner to the ps pump without rubbing itself on the water pump pulley, i don't think. anyway, just wrap a piece of string around the pulley configuration that you want then measure the length of it and go to the parts store and tell them "i need a XX inch 6 rib serperntine belt". they should be able to get it for you.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
someone on here did managed to do ac delete w/o the idle pully. Dont remember who though.
My car wont, I checked into it.
MrPackstin
Oct 25, 2017 08:09 PM
