So now what?
Old Feb 15, 2006 | 03:07 PM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
So now what?
So I finally took my car into a shop to have my service engine soon light checked out......
Well, they told me that they put it on two different diagnostic systems, and they can't figure out why it is throwing a code 43.
I have always taken my cars to this shop, so I seriously doubt that they are messing around with me on this one.
They told me that it's either the wiring or the computer. So is there an easy way to fix this? Should I trust a junk yard computer?
Help me out on this one, guys.........
Old Feb 15, 2006 | 03:17 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
if ya do get at Jyard one your should atleast open the case and make shure its not fryed i went to get one and the first three they showed me were fryed. finaly they gave me one that was not and i have been using it for 6 months now with no problems.
Old Feb 15, 2006 | 03:26 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
You could try a junkyard ECM, but I doubt that'll solve your problem.
If it's intermittant then you have a bad connection somewhere in the wiring. First place I would start is the EST connector. The latch tends to break off and the rubber inside doesn't always hold the connection real well.
i bet the problem is in the wiring back to the ECM somwhere. You'll have to check out the Tan/Blk wire all the way back to the ECM to make sure that you have continuity when you shake the harness.
Good luck,
Jeff
Old Feb 15, 2006 | 09:12 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
some things i would look at are the knock sensor pig tail, after a few years of use they get to where they fit loose, also check the knock sensor where the connctor plugs into it at for corrosion.
if it looks good so far, with the motor cold, loosen the knock sensor about 1 turn or so & then tighten it back up, the sensor may have a poor ground to the block.
Old Feb 15, 2006 | 09:49 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
It's an '85 2.8L...there's no knock sensor.
Old Feb 15, 2006 | 10:01 PM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
I'll try that tomorrow when I get a chance, if it isn't too cold. I also heard somewhere that the Electronic Spark Control module could be to blame. Where exactly is that at? And is there a way to test it? Thanks guys
Old Feb 15, 2006 | 10:09 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
his profile says 91, unless this is a continuation thread that we weren't all clued in on (no link to previous thread)
Old Feb 15, 2006 | 10:36 PM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
Nope, it's still a 1991 Firebird with the same 3.1 V6 with the same 180,000 miles on it..... I'm just trying to squeeze a little more miles out of it before I get fed up with it and yank it out.....
Old Feb 15, 2006 | 10:59 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Nope...that's my fualt. SORRY!!! LOL
I looked at the wrong profile...DUH!!!
Old Feb 16, 2006 | 06:43 PM
DENN_SHAH's Avatar
lol,... im glad im not the only one who does that sometimes
Old Feb 17, 2006 | 01:31 AM
Lex87's Avatar
Car: 1991 Firebrid
Engine: 3.1 MPFI V6
Where is the EST connector? I do have a broken clip on one of my connectors, but I don't know what it is for....
Old Feb 17, 2006 | 02:44 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
gray connector, single wire goes from the firewall to the coil or dizzy, cant remember which.
