3.4 Injectors in a 3.1
Old Jan 23, 2006 | 08:53 PM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Would I get any Gain or loss by putting 3.4 injectors on a 3.1. I can get the 3.4 injectors offa my old Camaro thats is a junkyard ..
Old Jan 23, 2006 | 09:47 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you can possibly get a little better performance from the 3.4 (17lb) injectors. I don't see the need for them seeing as how i'm running stock 15lb injectors on my built 3.1 but some people claim gains with the 17s. However, you have to get the computer tuned for them.
Old Jan 23, 2006 | 10:54 PM
The Computer tuned for them? I used all stock 2.8 stuff and the Computer with the 3.4 block and 3.4 injectors and it was fine. I thought all you have to do is disconnect the battery and let it relearn everything with the new injectors.
Old Jan 24, 2006 | 08:03 PM
Car: 91 Camaro
One thing is that you had the 3.4 injectors with the 3.4 motor but it probably still could have used some tuning. But, the 3.1 computer is set up to hold the injectors open for X amount of time (per pulse) at WOT; if you hold the 3.4 injectors open for that same time, you will send a lot more fuel into the motor. The computer won't "relearn" injectors. it will adjust at part throttle but that's becuase the o2 sensor reads the mixture in the exhaust and sends the signal to the computer and it adjusts. it doesn't work that way at WOT, though.
Old Jan 24, 2006 | 09:24 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Ah, so using those 24lb/hr injectors I've got lying around would be bad, eh?
Dang it. Something else I should probably sell....
Old Jan 24, 2006 | 09:51 PM
Car: 91 Camaro
wow...you'd need a very healthy n/a v6 or a mildly boosted v6 to need 24lb injectors!
Old Jan 26, 2006 | 09:52 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
No NA reason for 24lb unless it's a 3.4 spinning beyond 9000rpm.... on the other hand, I might want to buy those 24lb units...
Old Jan 26, 2006 | 01:03 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Sorry to thread jack, but you guys are on a reletivly similar subject and I didnt see any point on starting a new thread for this. Remembered see a list but I searched and cant find it.
I just need to know the engine code for the 3.1 V6... It's LHO isnt it?
My appologies again
thanks,
max
Old Jan 28, 2006 | 10:50 AM
Drew's Avatar
LH0 is the 3.1, yes.
Larger injectors aren't going to do anything except lower your gas mileage, foul your plugs, dirty up your exhaust, etc.
When I got my 3.1 bird the injectors were bad, I had access to a nearly new set of 3.4DOHC injectors. With those injectors the car would run, but just barely. It would only idle for about 45 seconds before it would flood and die. Plugs lasted about a week at a time. Performance was awful.
I swapped 3 of the original injectors that tested good, along with 3 mismatched 2.8 injectors and it ran better... After a while I got a couple handfuls of 3.1 injectors out of Lumina's and Grand Prix's and that combination provided the best all around performance.
In other words, if your stock injectors work (all six cylinders fire and the plugs look the same) then leave them alone. 17, 19, 22, 24lb injectors will only cause you problems unless you want to start burning your own chips.
Old Feb 16, 2006 | 10:14 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
My 3.1 has 3.4 injectors. There was no noticeable power increase. The car would set a code 45(rich) every once in a while. It still passed smog fine though.
Old Feb 16, 2006 | 10:19 PM
Engine: LH0 3.1L
Old Feb 17, 2006 | 09:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If you are looking to replace injectors in the 2.8 or 3.1 engines I would go with a Bosch injector (actually for any engine). The Multec's are just a terrible injector, not worth putting into any engine.
For the 2.8/3.1l engines there are some gray top Bosch injectors used in some Fords. These have the same flow rating as the stock injectors, which makes them a drop in. Here is the info I have on them:
Code:
Resist  Mfg.  Part     Color  Application
14.50 Bosch  E67C-AB  Gray   1986 2.9L, 3.0L
14.50 Bosch  E67E-BB  Gray   1986 5.0L SEFI
Not many apps listed, however, they may be used in others. If you are looking for used/cleaned/matched ones check the lindertech site. He sells them cleaned and flow matched just for the 2.8/3.1l engines.
RBob.
92-Formula
Dec 12, 2015 10:34 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
