need a diagram for vacume lines 2.8
Old Feb 17, 2006 | 02:55 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
OK, heres what happened. I bought this camaro and it needed a head gasket so my friend came over and tore the motor apart while I was at work. Needless to say he didn't mark where the vacume lines came from and broke a few, now I don't have a clue were they go. I asked him and he doesn't remember. So If anyone has a pic diagram I could really use it right now or anything for that matter. Thanks
Old Feb 17, 2006 | 03:18 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
look on the bottom of the hood by the latch it should be there on a sticker. If not i may be able to scan it for you from my chiltons book.
P.S. It makes it alot easier for people to help you if you put the Engine/ year/ trans and what not info in your profile so you dont have to type it every time you need help.
Old Feb 17, 2006 | 04:51 PM
micali's Avatar
Engine: 2.8
thanks, I'll do that. All my stickers have been removed. thanks for your help.
Old Feb 17, 2006 | 05:29 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Wheres KED85 when you need him.... sigh ...
Search function should facilitate this. There are literally hundreds of posts of pictures of vacuum lines on the forums here.
Old Feb 17, 2006 | 05:34 PM
bobdole369's Avatar
Car: 1989 Firebird
Carb version - non-85.
So you know, 1985 is a unique year for vaccum lines so every diagram you see, you should find out if its from 1985 or not.
https://www.thirdgen.org/techbb2/sho...m+diagram+2.8l
Old Feb 17, 2006 | 05:49 PM
bobdole369's Avatar
Car: 1989 Firebird
Here it is - stolen shamelessly from Tricksters post -
Old Feb 17, 2006 | 08:48 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
www.autozone.com also has online vacuum diagrams for practically every vehicle, also. Just tell it what vehicle you're working with and look at the repair guide or repair manual section. Vac diagrams are under drivability/emissions iirc.
Old Feb 24, 2006 | 01:53 PM
micali's Avatar
Engine: 2.8
found the diagram on the hood. Got it hooked up
Old Feb 25, 2006 | 02:16 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Karl was using my pic of the 85 car, which was a bastard yr. all the other yrs were slightly different.
Old Feb 25, 2006 | 06:53 PM
xplane's Avatar
Engine: 2.8 MFI
Thats what is weird about my car is it is an 85 but all the vac lines are the same as a 86 and the battery is on the pass side along withall the proper wiring there. its never been in a major accident and it dont look like any thing was swaped over if it was someone made darn shure to use all factor stuff and assemble it exactly as it would have come from the factory in 86+
Old Feb 26, 2006 | 12:31 AM
Engine: 5.7 / 7.4
https://www.thirdgen.org/techbb2/sho...ht=vacuum+line
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zane Story
Oct 8, 2015 12:40 PM
timonator
Sep 11, 2015 05:11 PM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
