need help with a few things
Old Mar 5, 2006 | 07:26 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Is the oil pressure sensor located on the oil filter, mine is bad and i would like to change it. Also how much is the sensor and how hard is it to change? also at idle my car kinda surges bounces back in fourth from like 650rpms to 800rpms i did a complete tune up except iac could this be symptoms of a bad or dirty iac?
Old Mar 5, 2006 | 09:16 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
sensor is down on the mount for the oil filter. IIRC it was a little pain in the ****.
bouncing rpm could be the IAC. Pull it out and clean it first. Then give it a while to re-adjust itself.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
