vacume presure
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
vacume presure
i have a 90 3.1 with cruse control and ac how much vacume should i read on a vacume gauge.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
20 in. of vacuum is good on a new motor, but when the motor gets worn, anything above 16 is good. As long as it's arouns 16 and steady, don't worry about it.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Re: vacume presure
Make sure to read it at a small, ported vacuum source also...such as the FPR line, HVAC control line, etc. Don't try and read it from a bigger line like the brake booster, it'll read really low.
