91rs 3.1 fan switch
Old Mar 28, 2006 | 03:30 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
91rs 3.1 fan switch
does the 1991 3.1 rs have a fan switch on the passenger side head that grounds to turn on fan, or is the fan controlled by ecm.
my chiltons/haynes diagram shows the dark green/w wire going to ecm and no fan switch at all.
Old Mar 28, 2006 | 04:05 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
My '91 Firebird's fan is controlled by the ECM. No switch in the Pass. side head. I assume the Camaro is the same.
When I first got the car the fan would run all the time when the key was on. Someone had grounded the Grn/Wht wire, I spliced in a switch in the ground wire so I could turn it off, and reconnected the relay to the ECM. Seems to work fine controlled by the ECM though, so I don't know why they had grounded it.
Old Mar 28, 2006 | 06:25 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Thanks, thats what i thought...
So they had cut the dark green/white stripe wire at the relay , and and ran it instead to ground?
Old Mar 29, 2006 | 04:22 AM
bru333's Avatar
Car: 1987 Camaro SC
Yup! Like I said, I don't know why they did that, it works just fine controlled by the ECM.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
