fuel injector question
Old Mar 29, 2006 | 05:00 PM
89firebirdguy05's Avatar
Car: Firebird
Engine: 2.8
Transmission: 5spd
k, howdi yall. I gotta quick question, do fuel injectors off a 3.1 liter fwd motor work on my 2.8? they seem a little shorter and stalkier? i got some for free and mine are all torn apart. Will they work?
Old Mar 29, 2006 | 10:48 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
If they fit, I don't see why not. People are always using all sorts of crazy injectors around here. If its a GM 3.1L most definitely yes. 3.1L I believe uses the 17 lb and the 2.8L (at least MY 2.8L) uses the 15 lb. It'll run rich but the ECM should compensate by shortening the pulse width.
Old Mar 30, 2006 | 08:11 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yep, should be the same, physically!
Though, I would recommend a re-tune of the car
Old Mar 30, 2006 | 05:38 PM
Car: Firebird
Engine: 2.8
Transmission: 5spd
well like i said there off a fwd car and they are a little stockier than mine, shorter and fatter..but fit. and why would i have to re tune my car and how
Old Mar 30, 2006 | 06:34 PM
bobdole369's Avatar
Car: 1989 Firebird
The 3.1L injectors are likely 17 pound injectors vs. the stock 2.8L 15 pound injectors.
The ECM is expecting a 15 pound injector but will be able to compensate by itself in order to run the motor correctly.
Typically when you tune the 2.8L, it needs more fuel (cam, heads, intake, headers, exhaust, PROM modify, stroke, port/polish, etc) - the next logical step is stronger injectors. Hence the recommended tune
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
