back from iraq, found a 3.4, but not sure
Car: 89 f-bird and some others
Engine: 3.4
Well I got home Tuesday. Cruised by the wrecking yard yesterday and found a 94 camaro 5spd with the 3.4 in it and 126k. The front end had been smashed in though, and it looks like the radiator might have shoved against the engine. Usually they pull the engine if it's good and sell the whole thing, but this one was left in it. They wanted $100 for it.
I'll have to check in the other 3.4 swap posts, I can't remember for sure how much extra I'd have to do to make it work with the auto tranny I have.
Anyway, I'm thinking it over. I still plan to buy a 4thgen TA sooner or later, so I may just put those headers on the 2.8 and call it good.
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
I second that ROCK ON!
Id see if they would let ya pull the crap away from the engine to see if anything is messedup. the trans will bolt right up with no problems.
Id see if they would let ya pull the crap away from the engine to see if anything is messedup. the trans will bolt right up with no problems. Thread Starter
Engine: 3.4
Thankyou thankyou
Well I'm busy all this week, so I'll stop by there again monday. If it's still there, I'll take a good close look at it, and go from there.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yuppers, welcome back, I should be back..............soon.
All you'll need to do is decide which wersion of the 3.4 swap to do and then pull what you need, sell all extras.
If you're planning to sell the car anyway, save your money and leave it alone. No one will pay more for it because its got more displacement, at least not unless its a V8.
