HELP!!!! CODE 32!!!!!
Old Apr 25, 2006 | 11:51 AM
metalhead5's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8L V6
Transmission: 700r4 big old automatic
Axle/Gears: 3.42 one wheel smoker
I have a 88 camaro with a 2.8L v6. I got a check engine light at highway speed andI pulled over and checked the codes. I got a code 32. Its an egr code if anyone can help me out that would be awesome. It seems to be intermittent if that helps
Old Apr 25, 2006 | 01:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You have a vacuum EGR (which is lucky for us, because they're cheaper to replace!), so check all the hard plastic vacuum lines that go to the EGR valve (one vacuum line on top), EGR solenoid (two vac lines and two wires), and EGR diag switch (one vac line and 4 wires). All 3 of those are on the bracket above your passenger side's exhaust manifold. A crack in any of those lines will cause a vacuum leak- and the EGR diag switch will "see" the leak and throw the code.
You can fix those vacuum lines by sliding a small section of windshield washer hose (5/16 inch) over the broken sections.
Old Apr 26, 2006 | 09:20 AM
metalhead5's Avatar
Engine: 2.8L V6
Yeah I checked all the vacuum lines, it almost seems like the vacumm switch isn't turning on. I'm not sure if its getting any power. Is there anyway i can connect it to a battery to see if the vacuum will turn on?
Old Apr 26, 2006 | 02:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well there's a code 32 chart in the http://www.helminc.com service manual; maybe someone can post it up... sorry, but I don't have my manual near by... you could always try to get a junkyard solenoid (cars usually don't wind up in junkyards just because the EGR goes bad) and see if that fixes the problem.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
