'86 Firebird will not run
Old May 4, 2006 | 06:58 PM
misterp53's Avatar
Car: '86 Firebird
Engine: 2.8L MPFI
Transmission: Automatic
Some background: 86 2.8 MPFI, compression 120 to 150 psi, spark at all plugs, timing verified at 10 BTDC, fuel pressure 35 - 40 psi, fuel flow 1/2 pint+ in 15 sec, voltage verified on hot side of injector harness, cranks well and will start once or twice but will not run with key released, code 34 showing on ALDL query.
Engine will start and run smoothly if fuel is atomizeded into the throtle body while cranking. Is there a reliable way to check the injectors without noid lights or a scan tool?
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
armybyrd
Aug 10, 2015 09:23 PM
