85 2.8 efi air intake sensor
Old May 22, 2006 | 08:24 AM
tjk62's Avatar
need location of for removal/installation
Old May 22, 2006 | 11:00 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
there are several intake sensors...
the IAT should be in air canister. unhook, unscrew, screw in re-hook.
the MAF should be easy to spot either mounted to radiator support, or eight off the throttle body. Again, unhook, take loose clamps. Replace, tighten clamps re-hook.
Old May 22, 2006 | 04:10 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
depends if its a camaro or firebird as to where the location is. if its a camaro, itll be in the dual snorkel, the big plastic piece where the air filters are under on the drivers side of it, the IAT that is. the MAF will be the canister looking thing between the throttle body and the snorkel.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
