stock cam
Old May 27, 2006 | 03:11 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
stock cam
What are the stock cam specs for a 2.8 V6?? Is the 3.4 cam any better? I did a search so please dont tell me to again.. Thanks
Old May 27, 2006 | 08:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The 3.4 cam is ever so slightly better, that it replaced the 2.8/3.1 cam. If you go to GM and ask for a 2.8 cam, your actually going to get a 3.4.
Dont remember the specs off the top of my head
Old May 28, 2006 | 02:13 AM
Well if I could get one for $5 would it be worth it..?? My engines already mostly apart so if itd do anything I think itd be worth it...
Old May 28, 2006 | 07:56 AM
Dale's Avatar
Engine: 350 S-TPI
Does it come with new lifters too? If not, the cost of the lifters would put it in the range of "not worth it".
Old May 29, 2006 | 11:04 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if youve already got it apart, id say just upgrade to a better cam. call summit and get the MTC-5 kit for $200. much better and you get new lifters. whenever you replace a cam, you MUST replace the lifters as well or just say your goodbyes now, cause it wont be long.
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
