popping 2.8l
Old Jun 3, 2006 | 07:20 AM
methanol30's Avatar
Car: 89 Camaro RS
Engine: 2.8lt
popping 2.8l
I have had my 89 rs for about 2 years now and it has recently started to pop back through the intake and I have no idea what it could be...
I cleaned and adjusted the IAC, replaced oxy, tps ,maf... any help?
Old Jun 4, 2006 | 01:05 AM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
The '87 2.8L Camaro I used to have developed this problem as well. The '87 would only backfire through the intake during warm-up. In that car's case, it was the Intake Air Temperature (IAT) sensor. After replacing that sensor, the engine's behaviour returned to normal and has been that way since. I discovered that was the problem on my car by looking at sensor data from the ECM. The readings from the IAT were WAY off.
Old Jul 15, 2006 | 02:59 AM
methanol30's Avatar
Car: 89 Camaro RS
Engine: 2.8lt
Passed the D.E.Q
Thanks for the reply, It has taken me a while to repair the problem and you were right it was the IAT sensor and the reading from the ecm were way off I also found that I had a stuck EGR valve. After fixing all of that my car has run great since...
Again Thanks alot...
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
bplessy
Sep 30, 2015 12:14 PM
aaron7
Sep 30, 2015 09:15 AM
Lmancha96
Sep 25, 2015 08:11 PM
