I lost my Haynes manual!!
Old Jun 20, 2006 | 08:38 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
What are the torque specs for the heads, rocker arms, and lowest intake manifold? Also does anyone know if the Hooker headers for a second gen 2.8 fit on our cars?? Thanks
Old Jun 20, 2006 | 09:14 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Head bolts- 70 ft lbs
Intake manifold to heads- 23 ft lbs
Rocker arm stud to head- 45 ft lbs
I saw on your cardomain page that you have a berlinetta with a 2.8 V6. These are the specs for that engine. If you have something different, let me know so I can give you the right values.
Last edited by 87IROCZ350TPI; Jun 20, 2006 at 09:19 PM. Reason: Automerged Doublepost
Old Jun 20, 2006 | 09:19 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if by 2nd gen you mean FWD, no. if you mean the 4th gen f-bodys 93-95 (3.4), no, they will not fit.
torque specs:
head bolts: 70ft/lbs
rocker arms: 0 lash + 3/4 turn
lower intake manifold: 23ft/lbs (i usually retorque 3 times) start from center and work out clockwise
he beat me to the post, if its for a RWD f-body, these are straight out of the haynes manual for an 82-92 f-body. if its for a FWD, ignore these.
Old Jun 21, 2006 | 01:58 AM
Thanks and yes its for a 2.8 V6 in my 86 Camaro.. As for the headers I meant a second gen F-body...
Old Jun 21, 2006 | 05:05 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
so the specs for a 91 3.1 r/s? lol thanks
Old Jun 21, 2006 | 06:11 AM
On the rocker arms you meant with 0 lash after the heads are on the block with the rods in place right??
Old Jun 21, 2006 | 07:07 AM
drdave88's Avatar
Engine: 6.0L
for the 3.1 its 40ft/lbs + 90 degree turn.
and yes its 0 lash once the heads are on and pushrods are in place.
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
tattmann
Sep 27, 2015 05:20 PM
