Retrofit factory intermittent wiper control?
Old Jul 2, 2006 | 01:56 PM
pgtr's Avatar
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
My '84 Firebird came with a lot of options but not intermittent wipers. What all is needed and how hard is it to retrofit intermittent wipers?
(I have tools for GM tilt steering column)
Any recommendations on online sources for used parts like this? Maybe a yard that specializes in parting out FBodies?
Old Jul 2, 2006 | 02:01 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
lets see.... you'll need the proper wiper switch/turn sig. switch, wiper module, and I think maybe there is a different motor assembly, can't remember and I'm on vac. so I can't check it on my car. I'm also certain the wiring is different to some degree
Old Jul 2, 2006 | 06:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
IIRC the motor is the same but the electronics in the motor cover are different.
Edit- Just checked, the part numbers for the motors are the same.
Old Jul 2, 2006 | 09:52 PM
pgtr's Avatar
Thanks!
I was figuring the wiper motor was the same but the steering column switch would obviously be different.
What I'm curious about is the wiring 'harness' if they would have typically installed a full harness regardless of option and thus the stalk switch would have simply been swapped...?
Not sure what to look for w/ respect to a 'module' ? - don't have a wiring diag handy at the moment either.
Old Jul 2, 2006 | 09:55 PM
Toehead's Avatar
Where are you located. I might have one lying around.
Old Jul 2, 2006 | 10:06 PM
pgtr's Avatar
Thanks - you have a PM
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
SlowAZ28
Sep 2, 2015 05:19 AM
