Aluminum DS
Old Jul 14, 2006 | 12:30 AM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Aluminum DS
I just bought a 4th Gen aluminum Drive shaft off ebay for $30 plus shipping. How hard is the install gonna be and what kind of differance is it gonna make on my car. I know the whole rotating mass thing is gonna benefit but is there anything else that I missed? Thanks
Old Jul 14, 2006 | 10:00 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Is it the LS1 Driveshaft?
It weights 1lb less then our v6 shaft. Might notice a little less vibration. Doubt you will notice the less rotating mass.
Old Jul 14, 2006 | 11:55 AM
Nope its an aftermarket one made by Quarter Master.
Old Jul 14, 2006 | 12:04 PM
Dale's Avatar
Engine: 350 S-TPI
Any idea the weight?
Install is very easy. Mainly, block the front tires WELL, and jack the rear end up as high as you can and block it.
Old Jul 14, 2006 | 12:25 PM
How do I block it if its up in the air??
Old Jul 14, 2006 | 12:39 PM
Dale's Avatar
Engine: 350 S-TPI
Ramps, jackstands, etc. Thats what I was refuring too. Jackstands would be better as you may have to spin the drivetrain a bit.
Dont leave it on the jack. You will have to do some wiggling, maybe a slight bit of prying as well.
Old Jul 14, 2006 | 12:57 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
never get under a car that isnt securely blocked/on jackstands on level cement or asphalt, unless you have a death wish.
Old Jul 14, 2006 | 11:48 PM
The guy I bought it from said it wieghs roughly 5lbs but he never checked.
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
