You guys with the 3.4 blocks, what numbers are you getting for compression test? 100-125-135-140-higher?
Still trying to find my vac leak here and this will be helpful.
I also sent a tech question to milling co. asking if the mtc5 is a steady vac cam, or flux vac cam
:beatsheadondesk:
:beatsheadondesk:
iirc i was getting about 160 in each cylinder (on stock cam)
Thanks, I dont think the cam will change it, just the worn rings/milage on engine.
Anyone else?
Anyone else?
I just ran a CR test the other day and I was getting about 190 on each cylinder. BUT, that's with dome pistons and (more importantly) new rings. Really, this info is a little irrelevant to most people here but just cause Dale asked for "anyone else"
