not starting
Old Jul 20, 2006 | 12:38 AM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
not starting
I just did the ol 2.8 to 3.4 swap. I'm just having a minor electrical promblem the starter doesn't even click when i try and start it. The feul pump comes on all the electrical with the car works fine, it's just not even attempting to turn over. I'm just bringin this up here cause i know someone who reads this might have had this promblem once or have heard it b4.
Old Jul 20, 2006 | 11:00 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
check your starter relay and make sure you have the right wires on the right terminals on the starter. Make sure they are tight... even remotely loose and you will have problems.
It is 95% that most of the time.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
