Adjusting mixture on E2SE electric carb
Old Jul 21, 2006 | 06:05 AM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
I took the car to it's yearly check-up which includes an emissions test and it barely passed. The mixture was way too rich, so I have to do something about it. The only real symptoms you get is backfiring when you step of the gas after accelerating when the engine is COLD.
Since the carb is electronically controlled, shouldn't it adjust the mixture by itself? The car is not giving any codes, the oxygen sensor is about a year old and the car is pretty much stock. The only "mod" is a K&N filter.
The ignition system is in good shape (supposedly). Cap, rotor and wires were changed about 1 year ago, plugs 6 months old. Where should I start looking for the problem? And can you adjust/should you adjust the mixture through the carb, or is the old piece of crap just worn out?
Old Jul 21, 2006 | 07:25 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
To answer your first question, yes the carb adjusts the mixture through the mixture control solenoid based on signals from different sensors (coolant temp., O2, and Throttle position).
Start looking at the simple things first before tearing the carb down. Check TPS voltage, check for proper operation of the MCS, replace the O2 sensor if it's been awhile.
86CamaroDan
Sep 29, 2015 10:08 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
Strick1
Sep 4, 2015 07:11 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
