700r4 mount up?
Old Sep 2, 2006 | 10:02 PM
Zeikjds's Avatar
Car: 1986 Trans Am/1993 Trans Am
Engine: 305 .030 over built/ LT1 Bolt Ons
Transmission: t5/700r4
Axle/Gears: 3.43 Posi/3.23 Posi
700r4 mount up?
I was wondering if the 700r4 thats on my 3.1 will mount up to a 3.8l?
Old Sep 2, 2006 | 10:20 PM
daves12secV6's Avatar
no it wont bell housing patters are different
Old Sep 2, 2006 | 10:26 PM
Zeikjds's Avatar
how would you fix this?
Old Sep 2, 2006 | 10:47 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you use a 3.8 engine from either an 80's or newer front wheel drive car or a 95 or newer F-car, the tranny will bolt up. It's only the rear wheel drive engines from the 80's and older that use the Buick/Olds/Pontiac bellhousing pattern.
If you have an older 3.8 with the B-O-P bellhousing and you are trying to hook up to your 2.8 metric bellhousing, you should give that up. The best way to fix that is to get another transmission. You can either use a V8 700R4 and then put your F-car tailshaft on it (to hook to your torque arm) or you can use a 2004R transmission with a B-O-P bellhousing and then customize your torque arm hookup to your crossmember. Save yourself some headaches and buy a SPOHN crossmember to adapt it; don't do any homer welding jobs on it.
Good luck!!
Old Sep 3, 2006 | 08:52 AM
Zeikjds's Avatar
it would be from a fourth gen firebird!
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
