FIREBIRD V6 5SP SWAP TO A LS
Car: 2000 FIREBIRD V6 5SP
NEW TO THIS....TRYING TO MAKE A STREET CAR FOR MY GRANDSON FROM MY 2000 FIREBIRD V6 5SP I WANT TO PUT THE BIGGER LS ENGINE AND NEED TO KNOW WHICH ENGINE AND YEAR IS BEST FOR THE CAR AND WHERE I CAN GET ONE. NOT MUCH OF A MECH AND NEED SOMETHING THAT IS TURNKEY TYPE I DONT MIND PAYING WITHIN REASON. HELP SOMEONE PLEASE...NO SCAMS I AM RET BLUE.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
edit: will post later, when I've not been up for umpteen hours
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
You might want to check out LS1tech.com Click Here . Being your building a fourth generation (93-02), you won't be running into half of the problems that most third generations (82-92) do...
But to offer an opinion, you'd definitely want to be looking for a donor (salvage preferred) car; rollovers, some theft recoveries, etc. You don't need a clean title of course (which makes salage titles even cheaper), your just after the entire drivetrain, along with the PCM, wiring and it's sensors. With a donor, you can also obtain everything else needed (provided its still good) in one shot; radiator, stock motor mounts (for now), heck even the fuel pump (I would even consider swapping thw entire fuel tank w/sending unit....
Going with a turn-key engine is great. However, their great for people looking to replace their tired V8's. If your starting off with a V6, sure, a turn-key engine sounds great as well, but again, the problem is that you need more than just the engine to get her on the road. Rather than going the crate engine route (while spending the coming weeks/months looking for the additional parts needed, afterward), I would definitely consider a donor car, first and foremost. Kill all of those birds with one stone....
Good luck!
Good luck!
Engine: 5.7 / 7.4
rubblerubble
Mar 13, 2016 06:57 PM
