Fan not kicking on, and what sensor is this? (pic)
Old Sep 12, 2006 | 03:42 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
The electric fan on my car always used to kick on at about 220*, and stay on until it had cooled the engine down closer to 180* (or so). Now it won't come on at all, even though the temps are rising above 220* during prolonged idleing.
With engine off I grounded A and B terminals on the ALDL, which causes the fan to kick on automatically. This tells me the fan and relay are okay, but it doesn't fix my problem. All I can figure is that a sensor is bad or the ECM. I have 3 sensors that plug into my coolant ports on the head. I have identified 2 of them as the ECM coolant sensor and the temp guage sensor, but what the heck is this 3rd one for? The fan maybe? My Haynes manual doesn't show it anywhere (ha! Imagine that!). It is located at the rear of the head on the passenger side and has a 1 wire connector going to it.
Attached Thumbnails Fan not kicking on, and what sensor is this? (pic)-camaro-022.jpg
Old Sep 12, 2006 | 06:00 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
That's the one that you need to replace. That's the Fan Switch.
The 2 located next to the thermostat are for the ECM(2 wire sensor w/yel and blk wires) and the other is for the guage/idiot light.
Old Sep 12, 2006 | 10:53 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
What is the one that is located at the rear of the passenger side head for?
Old Sep 13, 2006 | 12:53 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the fan on all but the 85 model year. 85's dont have a fan switch from the factory. they added it on later years cause the fans sometimes will not turn on as they should by the ECU alone(i should know, my ECU wont activate the fans)
Old Sep 13, 2006 | 10:02 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Got a new one and put it in today. Fan is working properly again.
Thanks for the help, guys!
The first time I went in and told them what I needed the genius behind the counter couldn't find it. He then wanted to sell me an aftermarket fan control switch and relay to wire in instead. I told him "why create more wires and parts under my hood when I have a perfectly good, tidy wiring harness that works fine? I know the part I need exists, it's just a matter of finding it."
Honestly, I don't understand people like that anymore.
Old Sep 14, 2006 | 07:35 PM
RSFreak's Avatar
Luckily my local parts guy is a regular on these boards (Iansane) and he knows thirdgens!
Old Sep 14, 2006 | 07:47 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
"""getting beat by truck's""""
Is that a joke dude? i know my 3.1 aint realy Fast" but damn sounds like somthing wrong with yours.......
Old Sep 14, 2006 | 09:30 PM
xplane's Avatar
Engine: 2.8 MFI
Kansas has no Emissions so its kinda hard to find stock trucks around here, and ya i have a vac leak or something. I also think that i have a bad injector that is causing the car to run WAY rich.
eightsixseven
Dec 16, 2024 01:50 PM
Chuck84TA
Jul 15, 2016 09:05 PM
stalkier
Dec 6, 2015 11:25 PM
krisner89
Oct 10, 2015 06:03 AM
tcflint
Sep 14, 2015 04:55 AM
