help with emmissions numbers
Old Sep 27, 2006 | 05:45 AM
mmmadreman's Avatar
here are my test results
25 mph rpm 1380 15 mph rpm 1375
standard reading standard reading
HC 157 407 fail 162 577 fail
CO 1.00 6.08 fail 0.91 6.75 fail
NOX 1121 427 pass 1227 391 pass
any help in fixing this problem would be appriciated..
Old Oct 1, 2006 | 12:25 AM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Looks like you are in the rich mode?..number things can cause this..plugged air filter,leaky injectors/bigger injectors(non-stock),non-accurate coolant temp. sensor,a cat.convertor thats not doing its job,a stuck open thermostat or non-existant one can cause this,a weak fuel pressure regulator?..do some checking and post what you find..good luck
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
