Aftermarket exhaust...
Old Oct 7, 2006 | 05:07 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
I recently installed a new dynomax muffler with magnaflow 3' tips on my '91 camaro 3.1 because the muffler and tail pipes were rotting out... Now I am considering a cat-back system but Im not sure if its necessary to change the muffler and tips aswell. Is it possible to now just change the other pipes and cat to the same specs as an aftermarket system? What is the main difference between the stock system and the aftermarket ones? Is it just he diameter of the pipes?
Old Oct 7, 2006 | 07:04 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you just need an I-pipe, since everthiing else has been replced. also get rid of the stock convertor if you still have it
Old Oct 7, 2006 | 07:32 PM
Bad-Newz's Avatar
ya thats what I was thinking. So I'm assuming the difference would be in the diameter of the pipe right? Whats the stock size? 1.5'? And aftermarhet is 2.5'???
Old Oct 9, 2006 | 05:19 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i think stock is 2.25. but the dynomax is 2.5 mandrel bent pipe.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
