89 2.8auto computer compatability
Old Oct 11, 2006 | 10:18 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
In the event my computer turns out to be bad, what other cars' computers are compatable with my 89 2.8 automatic. They said it would be a couple hundred dollars to get one new, but the local junkyard sells them for $35. And there's about 10 v6 thirdgens there.
Old Oct 11, 2006 | 11:09 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
Well considering '89 was the first year for VATs, you would have to get at least another '89 computer to keep that function, I dunno what would happen if you left the ignition module the same (if it would conflict with an older computer), and I can't remember what year they stopped using the cold start injectors ('88 maybe?) so you might not be able to use an earlier computer for that reason either. And of course, can't use the '90 & up without the conversion to speed density setup, but that might not be a bad thing anyway
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
