What's everyones idle set at?
Old Oct 17, 2006 | 05:44 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I was kinda curious. I'm trying to get mine to a minimum setting without stalling out the engine. I know it will vary between cars because of location in different ares (climate,altitude...etc.). Mine is currently set at 1000 rpms. Is there even a set idle for these V6s?
Ken
Old Oct 17, 2006 | 05:59 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
no there is no provision from the factory on these cars to set idle. If all your sensors are working, no vack leaks, good IAC, and all the other stuff is working correctly they will idle at 500 or so for a auto( mine is at 550-600) and 600 or so for a manual.
Old Oct 17, 2006 | 06:03 PM
zoddri's Avatar
Car: Camaro -88
Engine: 2,8 V6
Axle/Gears: yep, got that as well
The idle on 9 out of 10 cars is 500-750rpm. 1000 seems a bit high but I would'nt worry too much.
Naturally, this only applies when the engine is at its working temperature.
Some tuned japcars seem to have an idle of 2000rpm or so but I don't think that's good for the engine.
Old Oct 17, 2006 | 06:39 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what is your car's timing set at? my 94 hovers around/just below 1k rpms, but then sticks are usually set slightly more than autos
Old Oct 17, 2006 | 09:40 PM
xplane's Avatar
Engine: 2.8 MFI
Mine is at 12*btc
Old Oct 17, 2006 | 10:22 PM
daves12secV6's Avatar
mine idles about 650-700 with base timming @ 16*btc
Old Oct 18, 2006 | 04:39 PM
ken3983's Avatar
If it has'nt changed since I last checked it, my timing was set at factory 10*. If there is a vac leak, I can't find it. I'm gonna get some carb cleaner and work from front-to-back and top-to-bottom to be more thorough in finding one if any. I'm not getting any codes so thats good at least.
Ken
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
perZ
Aug 15, 2015 01:17 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
