please help
Old Oct 18, 2006 | 06:14 PM
91 v6's Avatar
Car: 2002 ranger(showtruck) 90 firebird
Engine: 3.1l
please help
i have a 90 bird with a 3.1 just swapped blown motor. mine rn great evcept for spun bearing. new one ran smppth before putting in. now idles great and runs great at anything above 1/2 throttle but sputters and kicks at low throttle/low rpm and smells like raw fuel. any ideas
Old Oct 18, 2006 | 11:14 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Bad/Mis-adjusted TPS; Bad MAP sensor.
You'll have to check all of the sensors and ignition components to make sure everything is hooked up right and functioning.
Old Oct 19, 2006 | 03:50 PM
91 v6's Avatar
Engine: 3.1l
map sensor sounds possible. had exhaust leak at manifold and was blowin right on it. was also thinking about the injectors. i have a spare map so ill try that and let ya know
Old Oct 27, 2006 | 06:20 PM
91 v6's Avatar
Engine: 3.1l
throttle position sensor
