Cost to Convert Auto Trans to Stick
Old Oct 28, 2006 | 11:33 PM
92Birdofprey's Avatar
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
Hi guys I was wondering if anyone knew how much it would cost to convert a 1992 Firebird 3.1 from Auto to Stick Shift or should I ask the question, is it even possible?
Old Oct 29, 2006 | 12:08 AM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
of corse its possible, now i ask a question are you doing the swap or are you going to pay someone to do it for you? answer that and i think you will get a responce.
Old Oct 30, 2006 | 12:22 AM
Car: 92 Firebird
Engine: 3.1
I'm most likely paying someone to do it for me.
Old Oct 30, 2006 | 09:11 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
wow...thats funny im getting a, 89 rs v6 5-speed and i wanna convert to automatic tranny
Old Oct 30, 2006 | 10:06 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
To convert, you're probably looking right around $1000 worth of labor to have someone R&R the tranny, R&R the center console, switch out the ECM and do the other little things that are involved in this kind of swap. That's IF YOU supply the parts. Otherwise you're pobably looking at around $2500 for the rebuilt trans, clutch and installation.
Old Oct 31, 2006 | 12:02 AM
Car: 92 Firebird
Engine: 3.1
I've never heard of someone trying to convert a 5 Speed to an Automatic, is there a reason why you want to do this
Thanks man, I heard someone say it cost around $5,000 to convert maybe he was wrong, I hope so at least.
Last edited by 92Birdofprey; Oct 31, 2006 at 12:05 AM. Reason: Automerged Doublepost
Old Oct 31, 2006 | 12:31 AM
daves12secV6's Avatar
u dont need to replace the ecm,just swap out the prom in the ecm for a manual trans prom.the hardest part of the swap is actually cuttin the hole in th efloor for the shifter,well that and getting up under the dash to bolt in the pedel assembly.
if u can drop the trans urself more then likely u can do the swap urself there isnt a whole lot to it
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
