Auto.trans. reverse problem
Old Oct 30, 2006 | 02:07 PM
chingon_k's Avatar
Car: Camaro RS 89'
Engine: V6 2.8
Transmission: Automatic
Hi everyone I have a problem with my reverse...sometimes it works fine and than suddenly i have to accelerate to make possible the reverse TT;...what do you recommend guys??? Do i need to change the trans. or there's any solution??? I really appreciate any advice regard this issue...thanks a lot.
Old Oct 30, 2006 | 07:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Did you try checking the fluid level? just to be sure.
Old Oct 30, 2006 | 07:38 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Sounds like the seals are leaking. You can buy a can of transmission seal rejuvinator (re-labeled brake fluid) to swell the seals for a temporary fix. Sometimes it last awhile. Most likely time for a teardown.
Old Oct 31, 2006 | 03:40 AM
chingon_k's Avatar
Car: Camaro RS 89'
Engine: V6 2.8
Thanks but I just tuned up a few weeks ago TT;
Old Oct 31, 2006 | 03:45 AM
chingon_k's Avatar
Car: Camaro RS 89'
Engine: V6 2.8
Thanks for the advise...seems to be inevitable the teardown TT;
Old Nov 2, 2006 | 08:40 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
tear it down before you blow something and then have to replace the whole tranny
Old Nov 2, 2006 | 08:10 PM
chingon_k's Avatar
Car: Camaro RS 89'
Engine: V6 2.8
Thank you ScottieB...I took your advice ^^; today...perhaps its gonna cost around $300 usd...one more thing do you have any advice to pass the smoke check? i have problem on low rpm TT...any tip will be appriciated...thanks
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
