A/C R-12 to R-134A help
Old Nov 23, 2006 | 09:35 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
I need help converting my A/C system to R-134A, wat do i need?
Old Nov 23, 2006 | 11:35 PM
jacob_coulter's Avatar
If the system is still in relatively good shape, I think it would be best to pay the $30-$40 pound and top it off with R-12. Just make sure all leaks are taken care of first.
I converted my car to R-134, and it was a lot of work, and it doesn't cool as well as with R-12.
If you go ahead with the conversion, at the least you're going to need all new barrier hoses, the entire system placed under a strong vacuum, and a new dryer. The old R-12 oil is incompatible with the new R-134 oil, so the system has to be clean. I have also heard it is a good idea to switch to a Blue Ford orifice.
There are some r-12 substitutes, such as Freeze-12 and autofrost, but I have heard mixed reviews of these products.
This is a great website to get additional info:
http://www.autoacforum.com/
Old Nov 23, 2006 | 11:51 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
just fill it up with freeze12, its a hell of a lot cheaper then r12, and works better then r134. if you do change to r134, you need, a new drier, orfice tube, plus fittings and r134( of course). ive done both, freeze 12 is easier, and you can find it at most part stores. G/L.
Old Nov 24, 2006 | 10:47 AM
firstfirebird's Avatar
My mechanic friend says the freeze12 is the best way to go, my a/c is now ICE COLD w/it.
Old Nov 24, 2006 | 12:18 PM
KBcobra's Avatar
Engine: 3.1L V6
Thanks guys i'll keep that in mind when i fix it in summer of 2007, its too cold right now lol
Old Nov 24, 2006 | 12:49 PM
It's good to hear some first-hand experiences from people having good experiences with Freeze-12. I've heard AC technicians say this stuff is snake-oil.
Of course, it's in their interest to say this so you'll spend over $300-$500 to have your system converted.
Old Nov 26, 2006 | 11:49 PM
Drew's Avatar
Or if you're cheap, you borrow a set of adapter fittings and a can tapper, buy 3 cans of R134A on sale at Walmart in December when they're $4 each. Vent the R12 into your approved containment system (garage) and refill with R134a from cans. You can speed the process by unplugging the harness from the evaporator canister and jumpering the wires. You could also substitute the oil charge for one can of 134A.
There's a right way and a wrong way to do everything, and to do a 134A conversion right means expensive specialty tools and pricey hardware. It's not really a shadetree project. On the other hand, the above cheap corner cutting method does work. It'll blow colder then the ambient air, sometimes it even results in R12-like performance. Worst case result is a scenario that requires replacing the compressor, drier, orifice tube, etc, but that's all stuff you'd want to do if you want it RIGHT to begin with.
Old Nov 28, 2006 | 04:23 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
silly question, but where is the orifice tube on our cars???
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
