no closed loop, some other stuff scanner said
Old Nov 25, 2006 | 01:45 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Car was idling for about 15 minutes and never went into closed loop. Had it revved up to 2k for a few minutes and the temp was up to 220.
o2 voltage varied from mV 408-480, also switched back and forth between lean and rich.
maf 5
proper step lean
base PW (ms) 1.6
loop open
o2 crosscounts 16 to 33
iac 20
A/F learned - no
integrate 128
temp reads fine, so I guess the sensor is good. I don't know if the maf is reading right or if the o2 is varying enough.
Can anyone make any sense of all that?
no codes yet (had the battery disconnected before driving 15 mins out to my friends house where the scanner is.
Old Nov 25, 2006 | 04:41 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
im having a similar problem,
my car seems like it doesnt want to go into closed loop.
my primary suspect is my recent valve adjustment,
I heard overtighting a tinsy bit of valve will possibly cause
stuck open valve at warm temperature(due to metal expading)
and ECM tries to send more fuel in to compensate for its losing compression.
so yeah if uve adjusted valve recently keep that in ur possibility list
Old Dec 1, 2006 | 11:56 AM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
I am having the same exact problem and my car stalls when i come to a stop
Old Dec 1, 2006 | 03:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The MAF reads 5? As in, 5 volts? Because (if my dusty brain remembers correctly), that's just the reference voltage. When the MAF works, it varies that 5 volts back to the computer.
Could be a bad MAF; they've been known to go bad and not throw a code. Have you done a physical inspection yet? The orange frequency film inside should be perfectly FLAT, no wrinkles/bends/creases etc. And my mechanic told me once that he saw a MAF that threw no code, but the circuit board inside was melted!
sogabe, I'd think your car would still go into closed loop, but you'd probably get a "rich" code from the computer.
DaSkinnyGuy, does it happen only after you've reached "highway speed" and come to a stop? If you stay under 40 mph, does the car stall at all? I'm thinking a stuck EGR (won't close all the way, causing a stall) OR, if its an automatic, the TCC solenoid could be sticking (engages TCC and won't release when you hit the brakes).
Old Dec 1, 2006 | 09:26 PM
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
This happens when the engine is fully warm and either i am decceling down a hill or when i am coming to a stop at a red light
BDR
Nov 7, 2015 03:05 PM
Nick McCardle
Sep 10, 2015 08:36 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
