newbrakes,pedel going to the floor
Old Dec 4, 2006 | 09:30 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok here is the deal , i replaced the front brakes cause pads where worn, now i notice driving around the pedel is going to the floor sometimes and feels as if i need to pump them once before coming to a stop... but as i compress the pedel i can feel the pads grabing and working it just seems as if i need more pressure in the pedel.... what should i check frist ? or what could this bee??i check fluid it could be old how offten should i replace the fluid ???
Old Dec 4, 2006 | 09:46 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
bleed your brakes, have someone pump your brakes(with car off), then have then hold the pedal down, loosen the bleeder valve on your caliper(starting from the one furthest from you brake master cylinder, and work torward the closest)untill all the bubbles are out of the lines. just make sure you fill the brake fluid as you go so no more air gets in the lines. and you should get a muc firmer pedal feel. easy as pic. sorry if there are typing errors, im typing with a broken hand. any oter questions PM me.
Old Dec 4, 2006 | 10:29 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Had you opened the brake system when you replaced the brakes? If not there was no way for air to have entered. If that is the case, it sounds like you may have lost a master cylinder.
Engine running in park.
Press pedal firmly.
Lift foot slightly, then apply pressure again.
Repeat several times.
If you can get the pedal to the floor and not leak fluid from anywhere, your master cylinder is history.
This is assuming you did not open up the system and let air in while you were doing the brakes. If you did, follow Leo_'s directions.
If you fluid is black and skanky, do it in either event.
Keep the brake fluid off your paint, it takes it off.
Have fun.
Last edited by TexasSilhouette; Dec 4, 2006 at 10:30 PM. Reason: Fixed crappy typing errors
LC2 TECH
Oct 13, 2015 11:53 PM
F-body-fan
Sep 19, 2015 09:02 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
