weird starting problem, still switches to open loop to much
Old Dec 7, 2006 | 10:56 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Pump primes and stops, turn key, cranks and doesn't try to fire at all. Release starter, pump seems to be priming again before I even release the key, crank it again and it fires right up.
One time yesterday I cranked it a second time without waiting a second and it sputtered into life, I had to play with the gas, and it ran rough for about 8 seconds.
Today just once it started up like normal.
I don't know if the fuel pressure leak is causing this or not. Saturday I'm getting another fuel rail and regulator. I want to try that before I get another pump. I still need to check on what the best pump is since I hear some suck even brand new. I wonder if that shop put in a cheap one that sucks.
doesn't seem to stay in closed loop when warmed up and idling. Even at 1500rmps it switches back and forth (75% closed I guess). Is it okay to drive with the A and B pins jumped to moniter closed loop operation? I assume it would be.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
