no start
Old Dec 14, 2006 | 11:57 PM
cobra's Avatar
no start
My 86 firebird has a 2.8 l mpfi engine . It was running fine then it lost power but still run . I limped home .I tried to start it and it cranks tries to start but wont . Changed out distributor cause it was rusty. It is getting fuel and spark. Ive checked the starter wires all have proper voltage. Im lost at what else it could be . Any sugestion ?The timing was checked and the distibutor is positioned right. When i try to start it seems to fire but just wont runThere is no smell of flooding. there is fuel going to the engine .i pushed on the pressure vaslue on plenum and fuel comes out .could i have a faulty pickup in the distributor
Old Dec 15, 2006 | 12:06 AM
daves12secV6's Avatar
does it backfire when u try to start it?
does it start to crank over and all the sudden liek just stop and then start going again like the starter just shut off for a second.
do u smell excessive gasoline smell from the ex system?
have u tried spraying some ether/starting fluid in the tb when u tried to start it just to see if it fires
Old Dec 15, 2006 | 09:44 AM
firstfirebird's Avatar
Have you checked for any codes in the ECM?
Click on FAQ's at the top of the page for instructions.
Old Dec 15, 2006 | 09:50 AM
cobra's Avatar
No the starter doesnt cut out . there are no codes stored .there is no smell of excessive gas.could i have a faulty pickup coil in the distibutor ?
no it doesnt backfire .checked timing its okay
Old Dec 15, 2006 | 10:42 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Time for a full tune up. If your dizzy cap was bad.....
time for plugs n wires too.
both 2nd n 3rd gens I have owned eat up ign parts like candy.
And they often just want new parts.
With computer cars yo ucan go a bit longer but pre 80s folks did full tune up twice a year. Darn cheap if ya get life warranty parts.
Old Dec 15, 2006 | 05:15 PM
cobra's Avatar
ok update i worked on it today .it now runs just as long as long as i keep starter going. once i let go it stops new cap rotor wires plugs . had ecm checked ok what else could it be
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
