Valve Covers
Old Jan 8, 2007 | 09:58 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Valve Covers
Was looking into getting a set of summit valve covers. I was wonders if the i would need to buy wing bolts for the new valve covers or would the stock bolts work fine? http://store.summitracing.com/partde...700+%2D78995+0
Old Jan 8, 2007 | 10:16 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
stock bolts should work fine
Old Jan 8, 2007 | 10:42 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
While i have the valve covers off, i might as well save up to replace the rocker arms and pushrods right? Im kinda on a tight budget so im not looking for the best. Do you have any idea good rocker arms that wont have clearance or tapping problems? I saw on a search that someone put 1.6 magnum roller TIP rockers on a 3.4 liter v6. From what i read everything that fits a 3.4 should fit a 3.1 is this true in this case? I know everyone gets tired of hearing this but will there be any noticable power increases? Is there any concerns for the new rocker arms to push the valve donw farther and hit the piston?
Old Jan 8, 2007 | 10:57 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
i would beleive the valve covers would fit, as well as the roller rockers. you might not notice much with just the rockers, but later on down the road, when you have the money to change cam, you should notice much more.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
