roller cams
Old Jan 11, 2007 | 07:15 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
roller cams
Anyone found a roller cam? I've found roller lifters, but no roller cams.
If you know of one, post the specs you know please.
Old Jan 11, 2007 | 10:22 AM
Dale's Avatar
Engine: 350 S-TPI
appears AE Clevite is only place that makes them. Contacted for cam part numbers and specs
Old Jan 11, 2007 | 09:02 PM
daves12secV6's Avatar
www.deltacam.com they can grind u a custom roller to ur specs very cheap,cheaper then buying a stock replacement
are u planing on installing a roller cam in a non roller cam block? if so how do u plan on keeping the lifters from rotating?
Old Jan 11, 2007 | 11:56 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
The cam I currently have is a Delta cam. Its the biggest hydrolic lifter cam they had for computer controlled vehicles (so they said).
Jay, didn't you mention that the lifters have to have a boss in the block? IIRC, the small block chev roller lifters have a bar that connects the two paired lifters. I was hoping to use 4.3 roller lifters in my car but the oil recesses around the lifters is in the wrong spot to get filled by the galley.
Old Jan 12, 2007 | 12:04 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have two listed in PAW, Crane Cams "CompuCam"
@.050=198-204 lobe sep 104 lift=.401-.403
@.050=204-214 lobe sep109 lift=.423-.423
The lifters are flat tappet and are included, sorry i could not find a roller grind for you.
Zane
Old Jan 12, 2007 | 05:59 AM
Dale's Avatar
Engine: 350 S-TPI
Travis, heres that link, forgot to email it to you.
Heres how gm handles the locks for the rollers. I am trying to think up something. If anyone has the part numbers to these little suckers, let me know it. I am going to try and find some in the yard this weekend.
http://www.fierosound.com/34engine/3400details.htm
Still no word back from AE
Old Jan 12, 2007 | 07:13 AM
Dale's Avatar
Engine: 350 S-TPI
Got a response, it went into my spam mail
229-2412= .412" lift, 197 duration
229-2326=.408" lift, 197 duration
- so it's a toss up!
Bill
I asked for other part numbers which he didnt give me. So if you find more AE-C roller cam part numbers, let me know.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
