Port & Polished Heads, has it been done?
Old Jan 19, 2007 | 02:33 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Hey guys,
Ive searched but havent found an answer. Has anyone sucessfuly port & polished their heads on a 3.1 v6? If yes was it worth the effort? Reason im asking is i found a pair of heads on ebay for 50 bucks, thought while the camaro is in the garage for the winter i could buy those heads and if i screw them up, im only out of $50.
Old Jan 19, 2007 | 03:14 PM
AlwaysDanked's Avatar
Car: 1991 Camaro RS
Engine: 3.1mpfi swapping in a 2.8mpfi
Axle/Gears: non-posi rear
go to this site
https://www.thirdgen.org/forums/search.php
type in: port and polish 3.1
there will be tons of information on doing this.
Old Jan 19, 2007 | 03:51 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
no actually nothing there says if it has been completed
Old Jan 19, 2007 | 05:15 PM
daves12secV6's Avatar
ben do a search for my user name in the v6 section, i posted pics a month or so ago of a set of iron heads i ported and sold.
Old Jan 19, 2007 | 08:56 PM
Old Jan 20, 2007 | 07:32 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i ported and polished mine a few years ago
Old Jan 20, 2007 | 09:01 PM
SS Ball3r's Avatar
ok, so im kinda new to cars in gereneral(i know a lot about mechanics, but not to much about doing upgrade stuff) but what does porting and polishing hte heads do. im looking to try and squeeze every bit of power out of my 2.8
thanks
Old Jan 21, 2007 | 10:02 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Its just what it sounds like. You port the ports to allow more air to reach the combustion chamber and to allow the exhaust to exit faster. Then polishing them is smoothing out the ports to there is little to no resistance.
Old Jan 21, 2007 | 11:57 AM
Car: 91 Camaro
a little more defined on polishing: you can polish the exhaust ports to look like mirrors and it will help flow. The intake side, you don't really polish much, you want to leave it a little rough to help the air and fuel mix. theory says that polishing an intake port too much can hurt performance because of the air and fuel not mixing as well.
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
kah992
Aug 19, 2015 02:55 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
