Lowering V6 rear
Old Jan 21, 2007 | 04:55 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Lowering V6 rear
I am looking into lowering just the rear of my car just to get a leveled look.I checked the other posts in the suspension area ,but it seems most are of the v8 model.I ant really looking to spend a lot on springs ,since the car is just mainly a commuter.I installed some new rubber on the rear to fill in the wheelwell and now its a little higher then stock.Has anyone lowered their v6 ,and if so what brand spring did you use?.I just want to do the rear?I would also like to know what the spring rate is on the stock rear springs?..are they the same as the v8 model?.
Old Jan 21, 2007 | 10:24 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
an inexpesive way would be to use compressors.
another way is to remove teh upper spring inserts & use some garden hose over the spring to keep it from squeeking/rubbing.
for the budget minded person, of course
Old Jan 22, 2007 | 09:01 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
try a search in the v6 forum and youll find what everyone thinks. ive got dropzones. and im wondering why you would only replace the rears? if the front sits lower than the rear, maybe youve got some stuff wearing out. id do all 4 if you get lowering springs, and youll need new shocks and struts. i dropped mine for under $250
Old Jan 22, 2007 | 11:25 AM
jstrdn90rs's Avatar
Actually,I installed 245/60 's on the rear and kept the 215's on the front which the rears are a bit taller thats why I want to lower just the rear..
Old Jan 22, 2007 | 04:26 PM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
lol, you want budget, I'd just cut the coil down a bit
Old Jan 22, 2007 | 05:23 PM
jstrdn90rs's Avatar
So it seems I have a lot of good options...once the weather gets better I'll drop the rear and see what I got.Thks guys..
Old Jan 22, 2007 | 06:33 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
This easy to do option is a better suggestion than cutting the coils.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
