23 PSI = fun and .....
Old Jan 24, 2007 | 08:37 PM
daves12secV6's Avatar
heh i hit 23 psi tonight,due to a stuck wastegate,only reason i noticed it was cause i noticed my afr gauge go into the red zone,so i glance over to see exactly were it was reading and i see 22-23 psi on my boost gauge.i let off it right away,but i think i hurt the motor,once i got it home carefully i let it sit and idle and i hear something taping,car still has good oil preasure and isnt smoking,
but i think i hurt a main or rod bearing,cause a few weeks ago i had snaped the oil pump driveshaft.i didnt do anything but drop in a new driveshaft.
though if im really lucky it just a lifter going bad
though i must say after going over 20 psi, i really think im going to have to upgrade the fuel system and go for more boost(on the forged motor anyways)
Old Jan 24, 2007 | 09:16 PM
firstfirebird's Avatar
I thought you maxed that turbo?! Does this mean that more PSI=more fun?! Immagine what 30+ is going to feel like, HMMM...
Old Jan 24, 2007 | 09:21 PM
no efficiancy drops off after 18 psi,over 18 psi it will still make more power but it will take more psi of boost to get the same amount of power,that it would say going from 7 to 12 psi.
Old Jan 24, 2007 | 09:25 PM
Gotcha.
Actually, that worries me. Was it carbon build-up that caused the sticking, or faulty vacuum lines?
Last edited by firstfirebird; Jan 24, 2007 at 09:27 PM. Reason: Automerged Doublepost
Old Jan 24, 2007 | 09:36 PM
i donno ill find out tom,prolyl carbon buildup, ive been running the car really rich latley so theres alot of soot in the ex pipes and on the wastegate outlet
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
