89 Turbo TA turbo switch location??
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
Bought a 1989 TTA last week. Previous owner disconnected the Oil sending unit and the turbo PSI switch. I got the oil switch reconnected but I cant find where the switch/sending unit for the turbo is located. Any ideas??
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
totally forgot, but dont paya attention top it mine was off at least 5 psi as compared to a new gauge on pillar..........
try the tta section:
http://www.turbobuick.com/forums/turbo-trans-am-tech/
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I think your looking for the map sensor, it should be mounted to either the firewall(behind and to the left of the coilpack)or on the ac/heater box. It's a standard GM 3-bar map sensor.
Hopt that helps,
Steve
Hopt that helps,
Steve
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Thanks guys. Im going to check it out in the morning. Previous owner had a "Scanmaster" wired into the car that supposedly gave a digital readout of those things but I just want to put the car back to stock trim..
Transmission: 5-speed/T-5
It should be a 2 BAR MAP sensor. All info I've come accross in rgards to this indicates 2 BAR MAP.
Car: 2013 C63C
Engine: M156 (P31)
The Grand National and T-Type/Turbo T used a 2 bar map sensor when equipped with a boost gauge(digital dash cars got a simple pressure switch instead of a map sensor). Reason is they ran less than 15psi from the factory and had a 15psi gauge.
The TTA runs 16.5psi from the factory and has a factory 20psi boost gauge which is why it comes with, and needs, a 3 bar sensor.
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Apr 30, 2019 12:14 PM
Pilotrick50
Sep 2, 2015 12:48 PM
Dialed_In
Aug 20, 2015 01:45 PM
