Smog pump question
Old Feb 8, 2007 | 09:09 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Smog pump question
Ok, i was telling my friend about the smog pump and how i couldnt put headers on with the smog pump. he said just to beat it and make a dent so the header can fit in. cause if it breaks it, when they inspect it, it will still be there. how much clearance is needed? Also the timing chain for a 2.8 will work for the 3.1 right?
Old Feb 9, 2007 | 10:17 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It doesn't matter if you still have the Smog Pump there because it's still a failure if you use the pacesetter headers on a 3.1 because they aren't approved for that engine, only for the 2.8
italiano67
Dec 11, 2016 09:21 AM
Bryan F
Aug 18, 2015 02:28 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
