valve cover question............
Old Feb 9, 2007 | 02:38 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Ok, the replacement gaskets I have are the felpro cork repalcement things, just like the originals. But when I removed the originals, they were the HARDEST things to remove. Almost as annoying as the plug in the 3.4 cylinder head lol If I ever have to remove them again....wow lol
Soooo...my questions are these...
1. Is there another type of gasket that comes off easier and seals good? Perhaps like the oil pan gasket? Any suggested brands? I know Hondas and I think some Toyotas use these type of rubber valve cover gaskets.
2. Should I just use RTV sealer instead of a gasket? Does it work better and come off easier?
ok thats it...for now lol Thank you as always!
Old Feb 9, 2007 | 03:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
This is one of 2 reasons I switched to fiero covers.
If you put a thin thin layer of silicone on both sides it should be easier to remove and also seal better.
Old Feb 9, 2007 | 06:02 PM
firstfirebird's Avatar
I scrapedoff the old gasket and used the cork ones, like you. Whan I re-assembled the engine, I sprayed some adhesive to the covers and one side of the gasket. Then coated the head side of the gasket with oil. Since then the covers come off nice, and the gaskets stick to the covers nicely and can be re-used.
BTW, did the gaskets stick to the heads or covers?
Old Feb 10, 2007 | 02:19 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Thanks for the reply guys! I'm gonna try that. I'll apply some RTV to both sides of the gasket so it'll seal good....and hopefully I won't have to remove them anytime soon though.
Dale, I can see why you went with the fiero covers.....they are sweeeeeet lol Sadly, very hard to fid fieros in Hawaii's junkyards.
"BTW, did the gaskets stick to the heads or covers?"
I would have LOVED for them to have stuck to the heads. They sstuck to the covers and it was pretty difficult to scrape them off with a screwdriver expecially in the groved area.....brings back baaaaaaaad memories haha
Old Feb 10, 2007 | 08:22 PM
I like the gaskets to stick to the parts that are easy to remove. Just don't want chunks of gasket in a place you can't clean it out easily.
Old Feb 12, 2007 | 07:32 PM
Dale's Avatar
Engine: 350 S-TPI
You cant find jack crap around here either. Internet and UPS rock
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
