gears
Old Feb 18, 2007 | 03:24 PM
rsfmash's Avatar
gears
I am changing my gears in my 1992 firebird to 3:42. Will my speedometer be off? And if so haw do I correct?
Old Feb 18, 2007 | 08:31 PM
daves12secV6's Avatar
yes it will be slightly off,u can correct it by buying the correct speedo gear for the gears u are installing,the new gear simply replaces the gear on the back of the vss sensor on the transmission.which can be removed with the trans in the car.its a single 10 or 8mm bolt to unbolt the sensor to get the gear out.
im pretty sure that 92's have 3:23 gears either auto or stick,so u wont see much of a gain going to 3:42's.i would suggest going with 3:73's or even a set of 4:10's
Old Feb 19, 2007 | 05:29 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
yeah, if your car is an auto you have 3.23s, if its a stick, you already have 3.42s. if you do a lot of highway driving, i wouldnt recommend changing the gears or your gas mileage is gonna take a poo.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
