MAF trouble code 34
Old Mar 11, 2007 | 05:43 PM
henke123's Avatar
MAF trouble code 34
My Maf is killing me! I´ve already replaced it once. Bought a used one. But still it doesnt seems to do its job? The idle doesn´t change if i unplugg the MAF or if its plugged in. I´ve checked the burnoff relay and the 20amp fuse. And the Maf do get 12 volts. (pardon my crappy english) But i still get code 34. WHY??
Camaro v6 2.8 mfi
Henrik L
Stockholm
Sweden
Old Mar 11, 2007 | 06:26 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Bad connection?
Old Mar 11, 2007 | 06:33 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
2.8 is right, it's probably either a loose, or bad terminal at one of the systems connectors. Either that, or a bad power/burn off relay(s). How did you check the burn off relay? You definitely don't want to assume that it's the MAF sensor itself....
BumpaD82
Feb 26, 2016 02:57 PM
Shane87irocz
Sep 22, 2015 06:21 PM
BWilcox
Sep 20, 2015 12:19 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
