92 3.1L Fuel Pressure Reg Hose to Nowhere
Old Mar 15, 2007 | 10:01 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
So, you have that one last hose that doesn't seem to go anywhere after re-assembly and the digital pic just doesn't see where the end went.. The Fuel Pressure Regulator on the fuel rail has a hose fitting that goes to a T fitting.. One hose from the T goes to the air (vacuum?) plug on the top of the air plenum (that rubber plug with 3 positions).. The other hose from the T runs to the passenger side to the ??? My picture didn't capture that end and I can't find anywhere that it appears to connect.. Even the end of the hose doesn't look like it was connected anywhere ever.. Is this hose just supposed to be open to the air???
Attached Thumbnails 92 3.1L Fuel Pressure Reg Hose to Nowhere-regulator-line.jpg
Old Mar 15, 2007 | 10:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It goes to the AIR pump control mechanism.
RBob.
Old Mar 15, 2007 | 10:57 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Do you have a pic of where that is located.. I can see what looks like a control on top of the air pump but haven't found any fitting to attach the hose...
Old Mar 15, 2007 | 11:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'll see about getting a pic to post. It will be later today before I can do that.
RBob.
Old Mar 15, 2007 | 11:10 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Great, thanks.. It won't be until later tonight before I can get back on it.. Have to go find one of those spring clips for the throttle linkage.. It did its little sproing thing across the ground last night.. Lost forever even with a high power magnet looking for it..
Old Mar 15, 2007 | 08:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Number 3 in the picture is the vacuum port. Interestingly enough it is used to force divert on decel. I would imagine this prevents backfires in the exhaust.
RBob.
Old Mar 15, 2007 | 11:10 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Man, thanks for the help.. I would never have found that as it ends up being at the bottom of the engine... Only had about an inch to slide my fingers in but got it on there.. Should have gone on before installing the pump... Pic tells a 1,000 words.. Thanks again...
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
