Fuel Pump / Electrical problem
Old Mar 24, 2007 | 03:02 PM
JohnTheBull's Avatar
Car: 1991 Firebird
Engine: 3.1L
Transmission: Stock
Axle/Gears: Stock
1991 Firebird, 3.1. I recently rebuilt the engine and tried to start it. Wasn't getting fuel. So I replaced the fuel pump and got fuel. But, I apparantly had the rocker studs too tight so I had to remove the intake, fuel rail, etc. to loosen them. Now, my fuel pump isnt pumping. It doesnt click on to prime when the key is turned.
Checked the fuse, its good. Changed the relay. Changed the ignition module. Still nothing.
I have power going to the fuse on the side of the engine compartment. I have power going to the relay. I have power to the Fuel indicator wire (purple wire) at the connector inside the fuel tank. But I have no power at the fuel pump (gray wire).
What am I missing? What is between the relay and the pump? If it was the pick-up coil or ecm somehow would i be getting power at the relay???
Old Mar 25, 2007 | 03:10 AM
Car: 1991 Firebird
Engine: 3.1L
Transmission: Stock
Axle/Gears: Stock
Re: Fuel Pump / Electrical problem
Any ideas?
Old Mar 26, 2007 | 02:57 PM
Car: 1991 Firebird
Engine: 3.1L
Transmission: Stock
Axle/Gears: Stock
.....umm..... nobody knows???????
Old Mar 26, 2007 | 03:06 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
IIRC should be a straight wire to the pump from the relay terminal 30. Does the relay energize when you turn the key to run?
You can also run 12V to the fuel pump prime terminal at the ALDL with the key off the pump should run. Not sure which terminal it is but I do know it is the red wire. It goes through the normally closed contact of the relay. That will verify the wire from the relay and the fuel pump.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
