How DO you get those injector clips off?
Old Apr 24, 2007 | 05:44 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I was gonna replace the injectors in my 3.1, but I can;t figure out how the clips come off without breaking them. Do the come off from the left,right,how? And what do ya use to do it with?
Ken
Old Apr 24, 2007 | 08:17 PM
daves12secV6's Avatar
Re: How DO you get those injector clips off?
i mean the lil wire clips??? if so push them in while pulling on the plastic connector.
most ppl pry the metal clips off,which results oin the lil metal clip going flying,and or a busted injector connector
Old Apr 25, 2007 | 08:39 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(laughs) Yeah I used to pry those clips out too! I think it was Vader on the board who laughed at me for it Pushing 'em in is /so/ much easier...
Old Apr 30, 2007 | 04:21 PM
rover420's Avatar
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
i think there the easiest plug to get off just push in the metal clip as u pull on them, like they already said. Good Luck
might as well change those o-rings and while ur at it thermostats are cheap and are a *&%$@ to get to but since ur already there might as well change it now. Just a thought
Old May 2, 2007 | 10:10 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I think you guys are talking about two different clips. There are the wire clips which hold the wiring harness to the injectors which you push in while pulling the harness out. And there are the little metal clips which secure the injectors to the fuel rail. I found it easiest to hold the fuel rail in one hand while using a flat tip screw driver to carefully push/rotate the clip. I just swapped out my injectors 2 weeks ago so this is still fresh in my memory!
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
